Dispel Posted May 18, 2013 Share Posted May 18, 2013 My hip files has 5 dop networks in it, but with the little "brain" icon I can only select one active simulation at a time. I would like to simulate all 5 at once, so that I can output caches to disk all in one run, since I know my system has the RAM for it. Why can't I seem to do this? Quote Link to comment Share on other sites More sharing options...
anim Posted May 18, 2013 Share Posted May 18, 2013 current simulation through brain icon doesn't mean that only selected DOP network is active, but it is the dopnet which will be used for the shelf tools if the simulation is enabled, then all DOPnets will simulate if something cooks them so if you for example import some objects from every DOPnet with Dopimport SOPs or anything and merge them with Merge SOP, you will see all of them updated at the same time so if you insert File SOPs to each branch and set to Write Mode or Automatic, they all will write your caches while playing the playbar just once, not necessarily multithreaded, that part is up to Houdini how it's optimized and how it can parallelize different simultaneous simulations of course you don't need to import them to the same object, just make all object displaying the geometry so it is updated while playing, if they have live File SOPs inside they will cache, but if you are triggering caches with ROP Output SOP or Geometry ROP then it is always one by one however it still can be frame by frame 1 Quote Link to comment Share on other sites More sharing options...
Dispel Posted May 18, 2013 Author Share Posted May 18, 2013 Awesome explanation Tomas, thank you! I am simming using dop IO node in SOPs which seems to not have a good way to wire it up to multiple nodes like a ROP does, but I think I will set up the file caches in sop networks like you suggest. Quote Link to comment Share on other sites More sharing options...
