giordiTD Posted May 20, 2013 Share Posted May 20, 2013 Hi guys how is it going? I am learning a lot in houdini ! now I want to make a custom motion path , I know .... houdini has one already but I dont have full controll over it , I wish to have a system where i can have control over everything and I believe it s a good learning experience ! So first step : I made a file where I added UVs to a curve and attached a null to the curve , If you guys don't mind can have a look at it and give me a feedback? What s good ,what s bad, other way to do stuff and so on? I am mostly concerned about how I retrived the maxUV param, I am not sure if it s the best way (basically promoting the UV attribute and using max as conversion ) Also other thing I am not sure about , since I didnt find a way to import or reference a detail attribute inside the vopsop I converted the maxUV attribute to point again and feed it inside the vopsop , is it there a better way? Thanks a lot guys! uv_plus_point.hipnc Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted May 20, 2013 Share Posted May 20, 2013 (edited) If you don't scale UV it will be between 0-1 always, so what's the point of normalizing it ? Also, I'm not quite following what you want to achieve here. What's the role of the null ? There is a lot of promoting attributes but I don't see a reason for this yet. Edited May 20, 2013 by mantragora Quote Link to comment Share on other sites More sharing options...
giordiTD Posted May 20, 2013 Author Share Posted May 20, 2013 If you don't scale UV it will be between 0-1 always, so what's the point of normalizing it ? Also, I'm not quite following what you want to achieve here. What's the role of the null ? There is a lot of promoting attributes but I don't see a reason for this yet. Hi thanks for the answer so , what i am trying to achieve is a custom motion path on which i compute manually position and orientation. So first step to reach the goal is find a point based on U value, So my curve didnt have a U map so I created it and then I normalized it. Actually you are right , after resempling the curve the UV got normalized , before it was going from 0 to NPT -2. Cool so I can get rid of the normalization part. If you check the new attached file you will see that U is not normalized. But anyway to answer your question : the null is just to visualize the output data so to see if the point is calculated correctly The attribute promoting was there for this reasons : (now there is no more need since UV is already normalized) - Get the maxUV value out of the UV array. - Convert it into a point attribute in order to be able to read it the vopsop Do you know any better way to achieve this two operation ? I am trying to see If I get workflow and way to do stuff correctly Thanks a lot notNormUV.hipnc Quote Link to comment Share on other sites More sharing options...
