Wire Solver?
Hello
I'm looking for any ressources to learn more about the wire solver. I can't seem to find anything out there that gives a clear approach...If I remember correctly, you have to setup a bunch of attributes to get it to work, but this may have changed since H10?
Thanks for any pointers
Alex
Create a curve, go to the wires shelf, and click "Wire Object"... then go to the rigid bodies tab and click "Ground Plane" so you have something to collide with. This will set up a dopnet for you, and any attributes it needs on your curve(s).
