Robert Posted June 7, 2013 Share Posted June 7, 2013 Hi, I have been trying to use a multiparm block to automatically create controls for a number of elements. I use the expression npoints("../") to get the amount of elements that I need controls for. When reopening the scene afterwards the attributecreate node that reads values from the multiparm block gives a warning that there is a bad parameter reference even though the parameter does exist. A temporary solution that seems to work is to toggle the cache input box of the null node that the multiparm block is in. Unfortunately this breaks copy nodes all over the place. The node will still copy but the stamp functions are broken so any stamp expression defaults to the 0 value. How can I solve this or how should I go about making an interface that creates controls for a changing amount of elements? Thanks. Quote Link to comment Share on other sites More sharing options...
anim Posted June 7, 2013 Share Posted June 7, 2013 (edited) what do you expect npoints("../") to do? I don't know where you are using it but I can imagine that it's pretty recursive, because it seems like calling this function from inside of some SOP (sopnet?, foreach?, ...?) and trying to get it's number of points but because you are inside you are probably changing geometry of that sop and therefore creating an infinite loop, or not? use npoints(opinputpath(".", 0)) to get npoints of the first input of current node or npoints (opinputpath("..", 0)) to get npoints of the first input of parent node maybe better post a scene with the problem or simplified version of it, otherwise it would be just guessing Edited June 7, 2013 by anim Quote Link to comment Share on other sites More sharing options...
Robert Posted June 7, 2013 Author Share Posted June 7, 2013 (edited) Sorry, I was unclear about the expression, it's a npoints() expressions that references a null node in an earlier network. I wasn't giving the actual expression. It could be an infinite loop but I dont understand how this only happens after reopening the scene. The operation that determines how many elements exist should always happen first. No information that is created in the multiparm block is being used before it. This simplified scene gives a startup error that my main scene doesn't but it is related to the issue I'm having. The null1 node contains the multiparm block. simplifiedVersion.hipnc Edited June 7, 2013 by Robert Quote Link to comment Share on other sites More sharing options...
anim Posted June 7, 2013 Share Posted June 7, 2013 I'm not sure what it hates about npoints() since plain ch("../line4/points") works even after reopening without errors but if you need to sample number of points python seems to work as well len(hou.node("../line4").geometry().points())[/CODE] Quote Link to comment Share on other sites More sharing options...
Robert Posted June 8, 2013 Author Share Posted June 8, 2013 It seems to hate any expression at all. Ch("../line4/points") probably works because its a reference and not an expression. The python code works to get the amount of points and it doesn't give an error on startup but now the recursive nature of the setup comes into play. Updating the amount of points updates the multiparm block interface but the values aren't used. To make any new elements that were copied on the new points visible the cache input of the null node has to be toggled again (I still don't know what this does but it seems to work). Am I approaching this type of control in a completely wrong way? Quote Link to comment Share on other sites More sharing options...
