Move nodes into geometry node
Sorry if this is too much of a nube question.
I have a ton (≈4K) of nulls imported from pfTrack in /obj.
What is the best way to move them into a geo node (such as /obj/foo) to keep them out of the way and allow turning them on and off?
Copy/cut and paste doesn't work. (I get a delete node when I paste, but that's a separate issue.)
Thanks!
John
you can put them into subnet
select, then Shift+C
then you can hide that subnet
or if you really want to have then as a single geometry, then you can use Object merge to get their centroids or icons to single geometry by inputting the pattern which covers all of them like "../../tracker_*/point1" for centroids or if you wants icons directly then "../../tracker_*/control1"
Edited by anim
Awesome! Subnet worked!
Thank you 'anim'!
I'm curious, why should it take many tens of seconds, even a minute, for Shift-C to execute?
Is there that much to do? I noticed the activity seemed to be single threaded, but still…
No, scratch that, I didn't see much response in the UI so I must have hit shift-C several times, so they were subnested seven times over.
Friday afternoon LULZ!
Thanks again!
John
