OpenVDB SDF data access
I am trying to access the data in a VDB sdf volume container that I use as a 3rd input in my node.
I managed to install the openvdb headers and everything seems to compile just fine.
All I'd like to do is basically access the distance and gradient values in the vdb sdf, given a world space position.
I found this beautiful method which seems to address the gradient question...
UT_Vector3 GEO_PrimVDB::getGradient ( const UT_Vector3 & pos ) const
And this is the code snippet I am using:
GU_Detail *sdfInput = new GU_Detail;
duplicateSource(2, context,sdfInput);
GU_PrimVDB myVDB(sdfInput,0);
UT_Vector3 samplepos(1.0,0.0,0.0);
UT_Vector3 gradient;
gradient=myVDB.getGradient(samplepos); // <--- CRASH
[/CODE]
... but when I try to use it , Houdini crashes (it crashes only on the line where I use getGradient method, it doesn't crash when I define *myVDB)
I couldn't find the method to access the distance value by the way.
I am pretty sure I am doing something terribly wrong cause of my limited c++ knowledge :)
Can someone help me to correct the above code snippet and add the method to access the 'distance' data ?
Edited by mrWolf
You need to get the VDB primitive from sdfInput, not create a brand new VDB whose owner is sdfInput. You should loop through the primitives in sdfInput() and find the VDB primitive to use. ie. loop through the primitives in sdfInput, and use the first one which returns non-NULL for dynamic_cast<const GEO_PrimVDB *>(prim).
Edward,
it worked perfectly,
thank you a lot for your help !
This is the code I'm using to access OpenVDB SDF:
UT_Vector3 samplepos(1.0,0.0,0.0); // just a random vector
float signdistance;
for (int np=0; np < numprims; np++)
const GEO_Primitive *prim = gdp->primitives().entry(np);
const GEO_PrimVDB *vdb = dynamic_cast<const GEO_PrimVDB *>(prim);
gradient=vdb->getGradient(samplepos);
signdistance=vdb->getValueF(samplepos);
cout << "distance:" << signdistance << "\n";
cout << "gradient:" << gradient[0] << " " << gradient[1] << " " << gradient[2] << "\n";
[/CODE]
p.s.
I have an additional little question:
what is the method to access the GEO_Primitive starting from GA_Offset ?
Edited by mrWolf
worked like a charm.
I've added the null check too.
Thank you a lot Edward, i'm learning a lot here !
You can do: prim = gdp->getGEOPrimitive(offset);
To be safe, you should check if vdb is NULL, ie. in your loop after the dynamic_cast<>():
if (vdb == NULL)
continue;
