JuriBryan Posted June 12, 2013 Share Posted June 12, 2013 Hi everyone, So I am working on a destruction shot right now where the ground caves in. The plan is to project the background image on the top side of the geo and use a procedural shader for the rest. The problem is that some how the rendered projection looks nothing like the image... well it does but it is saturated/desaturated more gamma less gamma and I can't get it match perfectly with the background image. I am using a constant shader with the image as a texture... that should actually be enough, right? I changed the gamma on the image from 0.454 to 2.2 and 1... nothing helps. Any idea what I am doing wrong? Cheers, Juri Quote Link to comment Share on other sites More sharing options...
sanostol Posted June 12, 2013 Share Posted June 12, 2013 mh, srgb sources need a gamma of 0.454545, linear images must not be modified mantra as any renderengine needs linear stuff to work with, but You viewer needs to apply a gamma of 2.2 so You see the correct image Quote Link to comment Share on other sites More sharing options...
JuriBryan Posted June 12, 2013 Author Share Posted June 12, 2013 I do know that. I correct the images for the correct colour space, but when I import the image into nuke it does not look like the original image. I am not at home right now, but I will post a image tomorrow morning. But to me it looks like there are some strange colour multiplications going on... no idea where they come from and what I could be missing. Thanks for your help so far! Juri Quote Link to comment Share on other sites More sharing options...
sanostol Posted June 12, 2013 Share Posted June 12, 2013 might help if You also post a texture example Quote Link to comment Share on other sites More sharing options...
JuriBryan Posted June 13, 2013 Author Share Posted June 13, 2013 HI, so here is a test render with the back ground. I tried to grade it to match the background but no matter what I do it just seams off. (the image is not graded) Here is also the file showing what I am doing with the texture I used. Hope someone has a idea on what I am doing wrong. Cheers, Juri rbd_01.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
