mikeporetti Posted June 19, 2013 Share Posted June 19, 2013 (edited) looking to blend two materials together using a map attribute. Is there a way? Edited June 19, 2013 by mikeporetti Quote Link to comment Share on other sites More sharing options...
gurazh Posted June 19, 2013 Share Posted June 19, 2013 (edited) Something like this ? blend.hipnc Edited June 19, 2013 by gurazh Quote Link to comment Share on other sites More sharing options...
siddd Posted July 1, 2013 Share Posted July 1, 2013 +1 Could really do with a way to blend materials outside of VOPs. I have two completely different mantra materials and I'd like to blend (not switch) between them based on a point attribute. Sid Quote Link to comment Share on other sites More sharing options...
symek Posted July 1, 2013 Share Posted July 1, 2013 This is currently one (from a very short list) of a limitations of Mantra. Materials are separate and arbitrary entities defined with vex code, which are hard to automatically blend. There is legacy way to turn a shader into VOP node and mix them inside material this way, but it is most of the time against current pipeline. You normally have to be smart with your custom components to build distinct blocks in Vops at front. There is nothing that can't be done in current setup, you can compose materials from any set of properties, it's simply not as easy as blending two shops. 1 Quote Link to comment Share on other sites More sharing options...
