houdini RBD Displacement
you can either compute the amplitude of the displacement as an attribute in SOPs and override shader's amplitude or scale parameter (whatever drives your displacement scale)
or you can compute that directly in the shader (if you simply want the displace to work only in when world Y < 0)
example for the later method
disp_by_world_y.hip
Edited by anim
