Parameters are gone
I was editing the Z scale of an object and now I no longer see the parameters for the other axes.
post-9983-0-60243200-1372529056_thumb.pn
The parameter is size. Not that there is a Z next to it. Not sure what I did but how do I fix it?
thank you
Edited by larmannjan
Guest mantragora
Try to set expression on it, than RMB and "Delete Channels". If it doesn't help the only other thing that I know that could help is full Houdini restart.
