JuriBryan Posted June 30, 2013 Share Posted June 30, 2013 Hi everyone, I am trying to use a field force, which is using a particle simulation, to drive a rigid body sim. The problem I am running in is, that since the particle simulation is not just a initial boost kind of thing but rather defines the shape I want the RBD sim to take the single pieces of the RBD sim have no rotational velocity. The field force has treat as wind turned on and works... but the single fracture pieces look static and not "real". So the question is, whats the easiest way to keep the motion and form that the pieces get through the field force but with an added rotational velocity. I was thinking about a noise field with very high frequency but that makes the pieces simply bounce around and makes the sim look as though its flickering. Any tip/solution is more then welcome! Cheers, Juri Quote Link to comment Share on other sites More sharing options...
bloomendale Posted June 30, 2013 Share Posted June 30, 2013 (edited) If you don't have your rbd rotating due to field force (even with Circle or Volume sampling mode) then it could be bug in Bullet solver. Try switching to rbd solver. It seems like bullet samples forces only in point mode. But even rbd solver works fine only if you're using volume collisions (so have sdf representation of the object). Edited June 30, 2013 by bloomendale Quote Link to comment Share on other sites More sharing options...
JuriBryan Posted July 1, 2013 Author Share Posted July 1, 2013 thanks bloomendale. works now. Quote Link to comment Share on other sites More sharing options...
