custom curve resampling
Hi there,
Was wondering how I could get the following outcome.
If I have a curve which looks like https://picasaweb.go...feat=directlink
I would like to resample each of the straight lined segments in following manner, If segment 0-1 is 8 units long, then it should have 9 points placed at intervals of 1 unit, starting at position 0. https://picasaweb.go...feat=directlink
In case, If the segment was say 8.4(float value) units long, then it would still have 9 points placed at intervals of 1 unit, but starting at position 0.2 so that it would look like, https://picasaweb.go...feat=directlink
In case of the curved segment, from 4-11, It should consider all the segments between 4-11, as one single segment and resample it in the above manner.
This is beacuse I want to preserve the shape of the curve and at the same time distribute points on the curve at intervals of 1 unit distance. So that geometry of 1 unit size can be instanced on the curve later on.
Thank you.
