amination Posted July 1, 2013 Share Posted July 1, 2013 Hello! Ever since I've added extra monitors to my machine things are getting a bit out of hand. Every time I try to extend my Houdini's display in other screens it crashes, whether using a floating panel or even extend its edge wide to wide. I'm not quite sure this is an issue within Houdini or it could be internally (Video Card, possibly). I'm using AMD, ATI Radeon HD 4600, and with 3 monitors. I'd appreciate your suggestions in advance. Quote Link to comment Share on other sites More sharing options...
gui Posted July 5, 2013 Share Posted July 5, 2013 I have 2 monitors here with diferent resolutions, and I thinks that´s why I´m having problems too. Some guys said that the desktop extensions should be handled by the video card´s drivers (at least, in windows), so you should check that in the amd pane. Here, I have a quadro 4000 and I still have some problems. Quote Link to comment Share on other sites More sharing options...
amination Posted July 9, 2013 Author Share Posted July 9, 2013 That might be it. I do too have 3 monitors and all with different resolutions. Though my Linux OS is having same issue as well, I definitely will check through AMD and video card panel, see if that'll solve the problem. Thank you! Quote Link to comment Share on other sites More sharing options...
