POP checkActivation function
Today I compiled the POP_Circleforce( which is in HDK samples/POP/ ), but the node has no effects to particles. Later I found the problems is that the function "checkActivation" always return 0. I checked the hdk document. There is one line that says: "checkActivation() returns 1 if the POP should be active and 0 otherwise.",which does not make sense to me. Finally I removed this function from .C file and the node works well now. I am wondering if any one know what the function actually means and when we need it in POP node.
Thanks
