change node menu with python?
Dee
Hi. I'm trying to build a node that will let a user import available assets and need help from someone with more experience. Our asset database is represented in a directory structure, which makes populating the lists easy. I'm listing the contents of folders and building a menu from that:
Directory:
Entry 1
Entry 2
Entry 3
Etc. That's how the menu should look. Then, the next menu uses the selection from the first menu to build its selection options. My problem is getting it to update when menu 1 changes. I need to execute the python menu script on menu 2 when menu 1 changes its value. Does anyone know how to do that?
It seems hou.pwd().cook(True)
Will do what I need, though it seems overkill to recook the whole node just for that menu script to execute.
Edited by Dee
