choppy particles output
donburisan
Hi guys,
I am running into choppy particles(the edges of the particles are too clean); even after setting oversampling to 4.
I tried using noise or turbulence to break them up.
It is probably because I am driving the particles using vdb generated from rbd simulation.
Any solution is welcomed for consideration.
Anyway, this is an experimental workflow so I would also welcome any suggestions or critiques if anything could be done better or wrong.
And thanks for reading.
Cheers!
choppy_particles.hipnc
