r1ver Posted August 1, 2013 Share Posted August 1, 2013 is it possible to convert some Blender3D shaders, such as this one: www.youtube.com/user/sterlingschiffdesign looks very cool! do anyone know how to make a similar network in Houdini, pls see the attached Blend3D network, thanks! Quote Link to comment Share on other sites More sharing options...
old school Posted August 1, 2013 Share Posted August 1, 2013 Yes you can mix BSDF's in Houdini, no issues, for all render engines. You can add them as well. And have them work with both render engines: PBR and raytrace. My example below is set up for PBR as I am using the F term in the VOP network. Here's the most simple way of executing pretty much exactly what the Blender network is doing for PBR: And the scene file: minimal_carpaint_shader.hip Personally I would not construct the network this way as you don't set yourself up for per-light exports of all the various shader components. It uses the older Lighting Model VOP simply because it has a colour parameter simplifying the network to get close to the blender network as you requested. If you wish to see one way to construct such a network, have a look at the Shading Model VOP, dive inside and look at the Reflection 1 network box as it contains the VOPs used to construct a reflection coat layer with both base and clear coats. One thing missing but not used in the Blender model is a user defined fresnel based on facing angle. That can be added with the Alpha Mix VOP which uses Alpha parallel, Alpha Perpendicular for intensity and a roll to control how the reflections appear on the surface. I added this to a second shader in the hip file. ---- Looking at this network, there is a nice improvement you can make. The way that you mix the two base paint layers to get an interesting rough metallic look is via a basic mix node and using the roughness parameter on the two reflection BSDF's. One thing you could try is to use a second fresnel term to mix these two or three base metallic layers. With rough metals, the IOR could be anywhere from 7 to 30. Whatever gets you the desired look or to match a real paint coat. Implemented in the third shader in the attached scene file. At a metallic base ior of around 4, you get pretty much the same result as the base BSDF mixing. Then you can go below 4 to get a darker look or higher to emphasize the bright color. It lends itself to a more organic look when the car is in movement and just gives you a bit more control than using just the roughness terms for the BSDFs and the crude constant mix value. There are just so many ways to implement a car paint shader these days. One of the criteria for a car paint shader depends on whether you have to mimic an actual paint on a car (no measured BSDF support in VOPs/Mantra yet...) or if this is for your own car paint and want it to look nice with your own ways to dial in your look. 2 Quote Link to comment Share on other sites More sharing options...
r1ver Posted August 2, 2013 Author Share Posted August 2, 2013 you are my hero! Quote Link to comment Share on other sites More sharing options...
jonp Posted August 5, 2013 Share Posted August 5, 2013 Jeff hasn't mentioned the best part: just like OSL intends to do, creating multiple BSDFs incurs a very small performance penalty for the final render. I'm a bit old school myself and was used to the old way where mixing many lighting models can cause render times to explode... only recently did I find out that this is not the case in PBR. Probably its best feature IMHO! Quote Link to comment Share on other sites More sharing options...
