Guest xionmark Posted May 3, 2004 Share Posted May 3, 2004 Greetings, After looking over the server logs I found there was a lot of downloads for the Real Flow plugins built for Houdini version 6.0 as well as 6.1, so both versions are ready to rock-n-roll. I'll have versions of the plugins for Houdini 6.5 done sometime this week. The tutorials for the Real Flow "Real Wave" SD file import is almost done and will be up in a day or two along with the i3D tutorials which will be on odforce[odwiki]. Attached are two test images of the vector fields generated from Real Flow data deforming geometry. Here's the URL: http://www.digitalcinemaarts.com/dev/real_...flow/index.html Have fun! --Mark Quote Link to comment Share on other sites More sharing options...
edward Posted May 4, 2004 Share Posted May 4, 2004 How about some sample movies? Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted May 4, 2004 Share Posted May 4, 2004 edward said: How about some sample movies? Sure, I'll post an annoucemnet when it's ready to go. --Mark Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted May 11, 2004 Share Posted May 11, 2004 Hi, Here's 2 simple tests showing the geometry deformations as the particle field "over takes" the geometry (I wait until the geometry is full enclosed in the particle field's bounding box to start the deformations). The tut's will come along shortly, just not enough time in the day for everything ... http://www.digitalcinemaarts.com/dev/real_flow/movies/ --Mark Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted May 25, 2004 Share Posted May 25, 2004 Hi everyone, I got the bug fixed for the Real Flow Export SOP for H6.5 (thanks Edward and Jeff!), except for IRIX, which should be soon to come as well. All the plugins seem to be playing nicely with 6.5, please report any bugs you may find. Thx! Here's the URL: http://www.digitalcinemaarts.com/dev/real_...w/download.html --Mark Quote Link to comment Share on other sites More sharing options...
