Trigonometric Function VOP question
How do I promote the "func" parameter? It's grayed out, but I'm sure I can access the switch to promote it somehow.
I'm using it in a for loop and want to access it as a parameter at the VOPSOP level.
Any ideas?
Thanks!
Guest mantragora
RMB on it and pick TypeProperties => Input/Output. As you can see there there is no func input specified in this operator, sadly you can't modify it. But hey, look on Code tab there, There is a code that this operator uses. Just pick File => NewOperatorType => VexBuilderType and recreate it with this input added.
