shenandyi Posted August 21, 2013 Share Posted August 21, 2013 hi guys, // Error: Error getting adding to initalShadingGroup. // // Error: No connection done for node 'file1' with // // mesh_AlembicNode // these codes is the only response in maya after reading the .abc file exported from houdini, I've read http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=123393&sid=ac2ede3f69a3313532272feb6a220a29 and delete all attributes except "P" cause the fbx file can't hold complex scene with hundreds of frames, abc is the best format! Quote Link to comment Share on other sites More sharing options...
shenandyi Posted August 21, 2013 Author Share Posted August 21, 2013 solved, it's seem like nothing to do with attributes. "open" abc first, then "import" abc(merge mode)...... Quote Link to comment Share on other sites More sharing options...
