tmp500 Posted August 22, 2013 Share Posted August 22, 2013 hello, i am trying to blend displacement maps for different facial expressions. thats the setup i used in maya http://www.3demo.info/wordpress/wp-content/gallery/notes/dynamic/correctivemaps-nggid0230-ngg0dyn-400x400x100-00f0w010c010r110f110r010t010.png now i am trying to convert that setup to houdini. ive got the head as an alembic file and the exported sliders(animated geo boxes from -1 to 1) which controlled the blend shapes(morphs) in maya. so what i would need to know is how to get the transform channel into shop land... any help would be very appretiated, thanks, phil Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted August 27, 2013 Share Posted August 27, 2013 Hi, If by transfrom channel you mean the blend shape values, I can think of two ways. 1) you can create the multipliers in the shader for the different displacement textures, drive them with a parameter and channel reference the parameter from the blendshape controls; 2) bake your blendshape values onto geometry using an attribute and have the shader automatically pick up those values at render time. Hope this helps, Cheers Quote Link to comment Share on other sites More sharing options...
tmp500 Posted August 30, 2013 Author Share Posted August 30, 2013 thanks for the reply, i basically solved it... i meant by transform channels actual geometry that was driving blendshape values... a joystick controller for blendshapes as an example: moving the controller (which is usually visible in the viewport) up, drives the left and right brow to go up, right upper corner the right brow, moving it down brow down etc... the asset gets plugged into the displacement, and needs the base displacement(the normal displacement map without an expression) added ontop of the joystickmap result. works so far, but it got a bit messy to work with all the different joysticks i had, slider restricted to Y, X only minus or plus X, Y. im sure there is a more elegant way in solving that asset, but worked fine for me. example.zipFetching info... JoystickMap000.otlFetching info... Quote Link to comment Share on other sites More sharing options...
