How compensate for Time Scaling in DOPs to preserve the same effect?
When I adjust Time Scale to be less than 1, i.e. 0.5, it changes the result of the simulation. Are everything in DOPs not supposed to be scaled as well? Basically I want to slow down the simulation. Do I have to go through every parameter and scale the non-zero values for forces, velocities, etc? I don't think it applies to everything.
What about expressions that use $SF, they should be adjusted accordingly, right?
Also I am adjusting the Substeps of the DOP network node accordingly which is what I thought was needed to preserve the exact same simulation result.
