Mikael Posted September 3, 2013 Share Posted September 3, 2013 (edited) Hi! I'm fairly new to houdini and I wonder how I can delete all points that have only two connecting edges? The purpose is that I have just used a cookie SOP and want to extrude and smooth my mesh but I don't want to have the extra points that the cookie SOP leaves me with, because then my mesh gets so wierd when I extrude and smooth. So any solution that solves my problem is very welcome.... Thanks! /Mikael Edited September 3, 2013 by mikael Quote Link to comment Share on other sites More sharing options...
kgoossens Posted September 3, 2013 Share Posted September 3, 2013 Can you post a screengrab of what you mean? Because sometimes having extra points is unavoidable. Quote Link to comment Share on other sites More sharing options...
Mikael Posted September 3, 2013 Author Share Posted September 3, 2013 There, I added some pictures. I could just delete them using a blast node, but since I'm working on a comercial and we often get changes I was looking for a quick way to handle this if it comes to changing the geometry in the future. Quote Link to comment Share on other sites More sharing options...
Macha Posted September 3, 2013 Share Posted September 3, 2013 In a vopsop you can count connected neighbours. Just group and blast. Quote Link to comment Share on other sites More sharing options...
kgoossens Posted September 3, 2013 Share Posted September 3, 2013 You can also use volume break instead of the cookie sop. It is more stable and it won't generate the points in between. Quote Link to comment Share on other sites More sharing options...
Mikael Posted September 3, 2013 Author Share Posted September 3, 2013 volume break works awesome, thanks Kim! but Marc, just out of curiosity how would I set up the vopsop? I'm not really kickass on vopsop... Quote Link to comment Share on other sites More sharing options...
kgoossens Posted September 3, 2013 Share Posted September 3, 2013 Here's an example with the vopsop. selectingPoint2neighbours.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Mikael Posted September 4, 2013 Author Share Posted September 4, 2013 Thanks for the fast and good answer! Quote Link to comment Share on other sites More sharing options...
