Splitting a curve primitive at each uv repeat
WaldoB
See attached file. I have created a line with some uv's first. Because the uv's for a line are perfectly aligned with 1 axis they could be cut with the clip node. To actually cut the line itself I first use the point node to transform every point to it's uv coordinate, then clip it and finally convert it back to its old position. In this example I used 3 clip nodes but you should put this in a loop. The carve node at the end helps to visualize where the new primitives start.
cutAtUvs.hipnc
  • 4 months later...
