KeyError('node') using kwargs in python Module
animknight
Python modules are tied to a node type, not an instance of a node. Depending on what you are trying to do, using hou.pwd() may work, though that is not guaranteed to return an instance of the node type. Usually you want to declare functions inside your Python Module and pass any nodes you want those functions to act on as parameters.
