Diego A Grimaldi Posted September 26, 2013 Share Posted September 26, 2013 Hey Everybody, I looked all over this and the Sidefx forum for the answer to my (presumably simple) problem but I couldn't find it. I am still very new to shops so here is my problem. I am trying to have an object with an alpha channel with a softened matte. I am convinced this is a very easy problem, but I really donno how to do it. Please help! Thanks Attached is a picture of my problem and the desired effect. Quote Link to comment Share on other sites More sharing options...
Aeonx21 Posted September 26, 2013 Share Posted September 26, 2013 This is just a hunch but try to render out each of them separately and then take the alpha of the sphere and blur it then apply it to the alpha of the smoke Quote Link to comment Share on other sites More sharing options...
Diego A Grimaldi Posted September 27, 2013 Author Share Posted September 27, 2013 Thanks for the reply! In the example I provided that would definitely be an easy solution, but in our actual shot it is necessary to accomplish this in render. We have a body of smoke being composited onto an object and parts of the simulation need to exist in front of the object but other parts need to be occluded (behind the object) at the same time. Any ideas? Quote Link to comment Share on other sites More sharing options...
rayman Posted September 27, 2013 Share Posted September 27, 2013 (edited) It is possible to do this in sops. Create Sdf represantation of the sphere (using iso offset SOP node). Then Add Volumevop with ramp or volumeblur node to control edge falloff. Use Volume Mix and multiply both volumes. SOP_volumeMix.hip Edited September 27, 2013 by rayman Quote Link to comment Share on other sites More sharing options...
Diego A Grimaldi Posted September 28, 2013 Author Share Posted September 28, 2013 Thanks a lot! I replaced the box in your scene with our pyro simulation and it worked as expected, but when I replaced the sphere with a more complicated mesh (a hand) I had difficulty getting the volume visualization to make a clear cut out of the hand. Played around with the volumevop and volume visualization but no luck. Any tips? Quote Link to comment Share on other sites More sharing options...
