maxguy Posted May 17, 2004 Share Posted May 17, 2004 hey guys,.. Im trying to create a whirlpool effect in an ocean,I tried particles with radial fields..not able to get it perfect..?and not able to get the thickness also.. i want to have two layers..one is the ocean and the other is the whirlpool formation using particles..? Any ideas on how to do the whirlpool effect? Pls help guys max Quote Link to comment Share on other sites More sharing options...
michael Posted May 17, 2004 Share Posted May 17, 2004 try building a whirlpool shape and birth particles off of that, then add more layers for chop and foam etc... it's like building a tornado - only you want the negative shape not the positive... Quote Link to comment Share on other sites More sharing options...
exel Posted May 17, 2004 Share Posted May 17, 2004 yup, like arctor said, make a whirpool shape... actually instead of mucking around with radial fields and vortex stuff, you might have a better time creating a funnel-shaped nurbs surface and use a Creep SOP (or Creep POP) and creep one or more streams of particles over the surface... Quote Link to comment Share on other sites More sharing options...
