RenderMan: unable to turn culling off
I'm trying to set up point-cloud occlusion. Therefore, I need to turn the culling off.
As always, I have added corresponding attributes to the geo node: "Cull Shading Of Occluded Surfaces" (ri_cullshadehidden), "Cull Shading Of Backface Surfaces" (ri_cullshadebackface) and set them to off.
But when I render and generate point cloud, these surfaces are obviously culled:
post-10135-0-86840600-1380718039_thumb.p
In the generated rib file, there are the following lines:
Attribute "cull" "bool backfacing" [0]
Attribute "cull" "bool hidden" [0]
Attribute "dice" "int rasterorient" [0]
[/CODE]
For some reason, Houdini outputs these 2 attribs as "bool" type, while they must be of "int" type.
If I manually edit the file replacing "bool" with "int" and render it, point cloud is created as expected (with backfacing surfaces present).
How do I fix it inside Houdini? Maybe, I've got some setting missing?
Houdini 12.5.469
prman 15.1
Edited by Lex-DRL
Looks like it's bug in Houdini.
I've exported ribs with the same attributes from 3Delight in Maya, and there were "int".
So I fixed it by editing RIBprman15.0.py located at houdini/soho/python2.6/. I've replaced there all appearances of "bool" to "int".
Now it works.
