zeekindustries Posted October 16, 2013 Share Posted October 16, 2013 Hello!!! I have a question regarding how to map the scale of a UV Project node (or any other value for that matter) using the bounding box of an object. I'm still getting used to the way the Houdini expressions work, so I would really appreciate a lot any input hta you could get me. I'm using an image sequence to trace some geometry, but I would like to have that traced geo to have the UV's properly projected since it is changing its form. One way that I tought of working this out is linking the UV SCALE values to something like this: UV Project SCALE X = bbox(myObject, sizeOfTheBoundingBoxInX) SCALE Y = bbox(myObject, sizeOfTheBoundingBoxInY) SCALE Z = bbox(myObject, sizeOfTheBoundingBoxInZ) I tried using the $BBX and $D_SIZEX but the UV Project node throws me an error and the scale gets evaluated in 0. Thanks a lot four your time guys!!! Quote Link to comment Share on other sites More sharing options...
Robert Posted October 16, 2013 Share Posted October 16, 2013 The second argument for the bbox() expression is D_XSIZE, without the "$" and the X in front. You could maybe also try using local variables such as $SIZEX in the UV project node. For all valid arguments for the bbox() expression I suggest you look at the help file. Quote Link to comment Share on other sites More sharing options...
