VDB container for FLIP
csp
It is not the fist time I am using vdb collisions in FLIP simulation and it always works fine for me, but usually there is fluid collide with a solid object from outside but in this case I want a fluid inside a vdb container like a bottle and I want it to stay there and collide on bottle's walls as it moves. Is there any way to do this?
Edited by cparliaros
Hi Christos,
Do you meen something like this?
Igor
Thanks Igor for the reply, this is exactly what i mean. I had the same setup but I had not computed the velocity of the container and pass it to the vdb. I think now, I understand a little bit more VDBs inside sims and how collision works.
I have some problem in the first frame where there is no velocity to compute and the part of fluid passing through but that can be fixed easily. Thanks again Igor.
For collision if you set the 'scale source volume' of 'source Volume' node inside DOP to 1 it will have the collision surface inside which is what you need in this case. -1 will make the outer surface available for collision.
I'm not at a system so I can't check Igor's file :(
Cheers!!!
-Ranadeep
Cheers!!!
-Ranadeep
Thanks for the reply Ranadeep, I had this part already and it works when your container is static but when there is animation/deformation you need to transfer its velocity from geometry to vdb and from there to dops. I found that some times may be some leak of the fluid but you can fix that by increasing the Scale Velocity on the Source Volume DOP.
Christos
  • 5 months later...
Hey guys,
sorry to bring up this old thread but I'm working on a shot and I'm running into the same problem.
In my case the FLIP at some point starts spilling (I assume due to the obj vel even though it doesnt move extremely fast)
I checked out both files you  guys posted and I haven't managed to make it work..
I've attached my scene file and geos
Could you please help me out?
Thank you :D
VDBLantern.zip
