yjcnbnbnb200 Posted October 22, 2013 Share Posted October 22, 2013 (edited) I have a simple flip scene. Now I want to make a simple effect, for example, each particle will be killed after his age reaching a given frame, now I want to achieve two things in DOP NETWORK: 1.How to add age attribute to flip particles? 2.How to write XXXXX>? such expression in GROUP node (I mean the group node in DOPNETWORK) Edited October 23, 2013 by yjcnbnbnb200 Quote Link to comment Share on other sites More sharing options...
yjcnbnbnb200 Posted October 22, 2013 Author Share Posted October 22, 2013 Quote Link to comment Share on other sites More sharing options...
vbk!!! Posted October 25, 2013 Share Posted October 25, 2013 This thread could help you http://forums.odforce.net/index.php?/topic/15419-flip-viscosity-driven-by-age/#entry95128 the main goal is to modify the FLIP source to add birth attribute ( value $T) Then you can use this attribute in a sopsolver. 1 Quote Link to comment Share on other sites More sharing options...
yjcnbnbnb200 Posted October 25, 2013 Author Share Posted October 25, 2013 This thread could help you http://forums.odforc...age/#entry95128 the main goal is to modify the FLIP source to add birth attribute ( value $T) Then you can use this attribute in a sopsolver. Thank you very much! Quote Link to comment Share on other sites More sharing options...
