amination Posted October 27, 2013 Share Posted October 27, 2013 Is there a difference between using Merge and Switch+Copy Stamp? Quote Link to comment Share on other sites More sharing options...
tmdag Posted October 28, 2013 Share Posted October 28, 2013 not sure what do you mean. One merges nodes another switches between inputs Quote Link to comment Share on other sites More sharing options...
amination Posted October 28, 2013 Author Share Posted October 28, 2013 If you notice in the hip file I've attached there are 2 OUT nodes that have same result. That being said I have used both in same operation, which got me different results from each merge and switch+copy, same amount of copies only slightly caused different outcomes in my operations. Any reason why this happens? SwitchVsMerge.hipnc Quote Link to comment Share on other sites More sharing options...
tmdag Posted October 28, 2013 Share Posted October 28, 2013 I don't see any difference between outcomes. What kind of difference you get? Quote Link to comment Share on other sites More sharing options...
graham Posted October 28, 2013 Share Posted October 28, 2013 It's hard to say what might be the cause without an example file of it misbehaving. In general though, I would say it would be better to just use the Merge method as it's less overhead and confusing since in this case you aren't really relying on copy stamping to do anything you couldn't already do with the Merge. 1 Quote Link to comment Share on other sites More sharing options...
