dennisvolkerts Posted November 13, 2013 Share Posted November 13, 2013 Hi... i have a easy question but cant find where to look If i hit tab inside a geometry content it doesnt create any. Its doing it outside my object. create inside content / create at object level doesnt seem to work. It ask me to place it on the grid. H13 last build!! / same problem in H12.5. i know there is some king of switch somewhere thnx Quote Link to comment Share on other sites More sharing options...
Robert Posted November 13, 2013 Share Posted November 13, 2013 It sounds like you are hitting tab in the viewport to place geometry. If you do it in the viewport the tool looks at the context setting which is located to the left of the blue help question mark in the viewport. The default is "create at object level" while you want to "create in context". This toggle only applies when using the tab key in the viewport though. As far as I know it always creates geometry in context when tab is used in the network editor. Quote Link to comment Share on other sites More sharing options...
