Whatsinaname Posted November 19, 2013 Share Posted November 19, 2013 Does anybody know how I can load VDB data coming from other software into Houdini? I created a simulation in Realflow2013, which can export data to VDB and now I wanted to see what I can do with this data inside Houdini. My problem is I cannot find the right nodes for importing VDB data, but I just find nodes for creating and processing VDB inside Houdini. Thanks in advance for any hints! Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted November 19, 2013 Share Posted November 19, 2013 The "file" node can read in .vdb files Quote Link to comment Share on other sites More sharing options...
Whatsinaname Posted November 19, 2013 Author Share Posted November 19, 2013 Ah, ok. Thank you. I also found it is possible via File > Import > Import Geometry Then one can plug a VDBVISUALIZETREE SOP in there, deactivate Leaves and turn on Meshing, and a meshed version of the VDB coming from Realflow is displayed. Works quite nice. Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted November 19, 2013 Share Posted November 19, 2013 Typically the "Convert VDB" sop is used for meshing Quote Link to comment Share on other sites More sharing options...
edward Posted November 21, 2013 Share Posted November 21, 2013 I believe the meshing option on the VDB Visualize Tree SOP is there for legacy reasons. Convert VDB > Convert to Polygons should be much faster. Quote Link to comment Share on other sites More sharing options...
