I am Trying to Stamp Filename based on PtNum
schiho
Hi Guys,
i am using the following expression on my "File SOP Node".
$HIP/Project/Models/WiggleGEO.`$F-fit(stamp("../copy1", "ptNum", -10), 0, 128, -10, 10)`.bgeo
on the copy node "Stamp Inputs" is active.
Then i get the error on the copy node: "Invalid Source geo2:file2".
I am sure you can reproduce this error.
thanks
Schiho
I think it doesn't work because for ptNum = 128, you'd have to have WiggleGEO.-9.bgeo at frame1.
Do you have that bgeo file otherwise better make sure fit result is always an integer less than 0?
It might start to work at frame 1 if you change it to $HIP/Project/Models/WiggleGEO.`$F-int(fit(stamp("../copy1", "ptNum", -10), 0, 128, -10, 0))`.bgeo
(10 changed to 0 ) and added int(....) to ensure result is an integer.
Hope that helps.
