TomRaynor Posted November 23, 2013 Share Posted November 23, 2013 Hi, I am trying to bake out a weightmap into UV space. I am turning the point attribute into Colour and rendering it out as UV Render object. My question is how to I get this to render out with absolutely no pixel filtering. I obviously don't want my attributes to blur at all. I had a look at the mantra node help but I couldn't seem to see the option for no pixel filtering... I'm sure I am being stupid and that it is just something like "None". Does anyone know? Thanks! Quote Link to comment Share on other sites More sharing options...
csp Posted November 23, 2013 Share Posted November 23, 2013 Hi Tom, Mantra node > Properties > Output > Pixel Filter : minmax idcover or from drop list : object with most pixel coverage (no filter) You can use different filtering per Image Plane in the case you are using passes. I hope that helps. See you on Monday! Quote Link to comment Share on other sites More sharing options...
