Houdini 13 foam lifespan
hello,
Someone know why the foam from whitewater doesnt dispear in houdini 13? only can be dispear using Life Expectancy in whitewater_emitter but that is not normal, must dispear using foam> min life span and max lifespan, i have tried 0,1 (default are 2,4)...
probally is buged? i am using houdini 13.0.237, in H 12,5 the foam works fine and dispear...
thanks in advance
Carlos
