magneto Posted November 24, 2013 Share Posted November 24, 2013 Hi, In this tutorial, they use the Gas Solver: http://www.sidefx.com/index.php?option=com_content&task=view&id=1234&Itemid=262 But it's not available in H13 and I tried all available Gas Solvers and none of them accepts the connections required. Opening those scenes also do not work as the node shows as a Merge DOP and fails to cook because of input 1. What's the replacement for the Gas Solver DOP in H13? Multi Solver DOP? Thanks Quote Link to comment Share on other sites More sharing options...
ikarus Posted November 25, 2013 Share Posted November 25, 2013 You can use a multisolver dop or even a gas substep dop to run multiple solvers on incoming objects. Look at the smoke solver innards for reference on fluid solver guidelines. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted November 25, 2013 Author Share Posted November 25, 2013 Thanks ikarus, I thought maybe Multi Solver DOP was added after the Gas Solver DOP to be a general purpose solver. I was using that anyway Quote Link to comment Share on other sites More sharing options...
magneto Posted November 25, 2013 Author Share Posted November 25, 2013 Also does anyone know why you had to use a Geometry Copy DOP using the Gas Solver because otherwise nothing happened to the geometry, but now in H13, it works without using the Geometry Copy DOP? Not sure if it's a workflow change or because of the way the new solver works directly on the Geometry data. I assume not many people know this due to Gas Solver DOP being much older. Thanks Quote Link to comment Share on other sites More sharing options...
