Simonvdb Posted November 27, 2013 Share Posted November 27, 2013 Hey, Is it possible to translate (using the transform sop) from the pivot position instead of the world's origin? kind regards, Simon van den Broek Quote Link to comment Share on other sites More sharing options...
magneto Posted November 27, 2013 Share Posted November 27, 2013 I don't think it makes a difference, since it's just an offset Perhaps you mean translating in the local coordinates of the geometry? In that case the transform matrix should be aligned with the geometry. You can do it using a VOPSOP. Quote Link to comment Share on other sites More sharing options...
Simonvdb Posted November 27, 2013 Author Share Posted November 27, 2013 thanks for the reply! I will try using a vopsop 1 Quote Link to comment Share on other sites More sharing options...
dobin Posted November 27, 2013 Share Posted November 27, 2013 to center the pivot in Transform SOP type $CEX, $CEY, $CEZ in the pivot position Quote Link to comment Share on other sites More sharing options...
Simonvdb Posted November 30, 2013 Author Share Posted November 30, 2013 to center the pivot in Transform SOP type $CEX, $CEY, $CEZ in the pivot position Hey dobin, I knew that one already but I still appreciate the reply. Quote Link to comment Share on other sites More sharing options...
