particle start stop and collision
rod
I am doing a project in school where particles will be moving like ants on the ground.
Here's one of my references:
Here are my requirements:
1. make particles travel in a line with noise and ray it to the ground.
2. have some of the particles start and stop midway and after a certain time have them move forward again.
3. when particles collide, they would stop momentarily and then start walking again.
So far, I've managed to have the particles travel in a line with noise applied. I am now on the part where some particles, while in motion would stop (not at the same time ) and after a short pause would start walking again.
I've been trying for several days now experimenting with basic Source, Force, Collision, and Attractor nodes.
So far the most success I had was setting the "scale" value of the force node to 0 based on time but it stops all existing moving particles. I only want some of the moving particles to stop. And the way it stops should not be a gradual stop as if the particles are on ice or water (Ants start and stop quickly).
The next was using a voppop, I had a simple multiplier with a constant (this will act like my switch for testing purposes). I can get the quickstop that I wanted but particles stop and never start again. I just want maybe 2 to 3 moving particles to stop and then after maybe 1 or 2 seconds to start again.
Any suggestions will be greatly appreciated. I've attached a simple dev test and my actual project.
Cheers,
Rod
particle stop start dev.hip
post-10584-0-67895100-1385757182_thumb.j
ProjectAnts5.hip
