UV dilate
bandini
i can see a two step process, take your geo into UV space: (I'll refer to this as UVGEO)
divide delete interior edges to leave a "curve/line, polyframe to get the tangent vectors pointing outwards,
(or take the normal and cross it with the y vector once you moved your geo into uv-space)]
then ake your UVGEO ( attribtransfer your normals with a minimal radius (0.001)
and peak along that vector, it should only move the outside points. can create some issues in corners though.
Thanks, Freek. One more quick question, testing another method... Do you know of any way to group uv boundary points?
Adam, have u tested using edge groups? I don´t know how your geometry´s topology looks like, so, perhaps it´s a dumb suggestion...
