zhyravetsky Posted December 3, 2013 Share Posted December 3, 2013 change offset anim in instance like whithout copy stamp... i have a bird i whant to make difrent offset of anim per point but whithout copy stamp in instance .... Quote Link to comment Share on other sites More sharing options...
gui Posted January 10, 2014 Share Posted January 10, 2014 Hi, I had the same problem yesterday and didn´t found the solution that I wanted (using the instance obj), but I ended up using packed prims, since copy sop suports it. U should give it a try. I think it works somewhat similar to point instancing... Quote Link to comment Share on other sites More sharing options...
anim Posted January 10, 2014 Share Posted January 10, 2014 just use instancefile string attribute populate it with file paths per point, instance procedural will then use that file as delayed load per each point Quote Link to comment Share on other sites More sharing options...
zhyravetsky Posted January 11, 2014 Author Share Posted January 11, 2014 example Quote Link to comment Share on other sites More sharing options...
gui Posted January 11, 2014 Share Posted January 11, 2014 example where? Quote Link to comment Share on other sites More sharing options...
