Is there a way to distinguish between opening a file vs launching Houd
magneto
I want to do some UI related actions if Houdini is launched by double clicking a hip file, but not when opening a file by using File -> Open.
456.py is executed in both cases. Is there a way to distinguish between the two so I can add this code inside 456.py that would bypass the UI related code inside?
Only way I could think of is to save the hou.hipFile.name() to somewhere and do a comparison. But I imagine this might slow down the startup slightly and has more book keeping that needs to be done, for example resetting the value back to some default on Houdini exit, etc.
From what I can tell, there's no way to really tell how Houdini was launched.
You could probably do something like the following though:
1. In pythonrc.py, store some variable in hou.session (hou.session.starting=True)
2. In 456.py, check the status of hou.session.starting and if it's True you are starting up Houdini. You could then check hou.hipFile.name() to see if you are starting up with a hip file (not untitled.hip). Also, you need to set hou.session.starting = False afterwards.
3. If you then do another File > Open, the starting variable is False so you know you are loading a hip from inside Houdini.
Thanks Graham. I just did it and it works great. Instead of using pythonrc which I couldn't find anything in the help, I am setting the variable in 123.py which is only executed when I directly launch Houdini. If I double click a hip file, then only 456.py seems to be executed.
So I am only running it if I can find the member in hou.session. If it's not there, I create it in 456.py so that when I open a different file, it doesn't run again.
