stkeg Posted December 12, 2013 Share Posted December 12, 2013 how can i cumulatively append points in the HDK? for example i have a simple network a | b a has 10 points. b is a sop_node that appends a point to the gdp gdp.appendPointOffset(); so for each frame, b now has 11 points. what i would like to happen is for the points to accumulate over time. ie. the next frame, the number of points is 12, then 13, etc. but for each frame, it's always going to be 11. i guess it's because i always going to be 11 because i have 10 points coming into the network at every frame. i guess i need to append the point not to b, but to a? i.e. get the gu_detail from the input? Quote Link to comment Share on other sites More sharing options...
edward Posted December 14, 2013 Share Posted December 14, 2013 Put your SOP into a Solver SOP: http://www.sidefx.com/docs/houdini13.0/nodes/sop/solver Quote Link to comment Share on other sites More sharing options...
