Marking broken glue pieces with an attribute
frankengen
Hello,
I was wondering what is the best way to mark pieces that are broken free from a glue network. I have made a sopsolver that gives random velocity to different pieces and makes the geo explode and jumpe around. I want to give them a different behaviour once they are broken free.
Here is a hipfile attached
Thanks in advance for your help.
Cheers,
Frank
popcorn_01.hipncFetching info...
I thought that maybe I could compare strings in vops, so I could compare the names in the packed Object to the name of the glue constraints. But when in wops the import attribute does not have a string option, and the bind import does not have a opinput option to check for the second imput. Does anyon have any idea. cheer
Now I am one step closer. I got the string of the second input with the get attribute node. Now i just need to understand how to use the for loop node property. If anyone could help me I would really appreciate it. I think its not far of. Basically im not sure how to hook it up properly, i dont know what im doing wrong, because it looks like it should work.
If anyone could have a quick look i would really appreciate it.
Thanks
popcorn_03.hipncFetching info...
