Slicing a Single Frame for Render
you can use the command
Mantra -H node1,node2
where "node1" "node2" are the names of the machine. Mantra will then distribute the render buckets across of the machines.  This is in Mantra/Main/Command- the pull down menu on the right lists this option too under Network rendering.
