prashantcgi Posted January 9, 2014 Share Posted January 9, 2014 Hi Guys! Sorry if its a repetitive question I want to create the points at the intersection of two geometry in easy way as i have a grid like geometry with lot of intersections and i'm facing problem while simulating it using Bullet SOP Please check the attach sample image. Thanks! Quote Link to comment Share on other sites More sharing options...
dpap Posted January 9, 2014 Share Posted January 9, 2014 Hi Prashant! I thought to to give this a try.. Is this what you mean? intesect.hip Quote Link to comment Share on other sites More sharing options...
prashantcgi Posted January 9, 2014 Author Share Posted January 9, 2014 Thanks for the solution!!!!!! Thanks dpap Only problem is, I have to separate all vertical and horizontal geometries so that i can do a cookie is there any other way also, without cookie Quote Link to comment Share on other sites More sharing options...
gui Posted January 9, 2014 Share Posted January 9, 2014 what do u mean as intersection? Since the geometry is made of poligons, is the intersection of sides or faces or a "theorical" intersection, like 1 point in the middle of the overlapping geo? Quote Link to comment Share on other sites More sharing options...
prashantcgi Posted January 9, 2014 Author Share Posted January 9, 2014 (edited) As per the image: The points are only at the ends of the geometries but theres no points at the intersecting place By intersection i mean to say intersection of primitives Edited January 9, 2014 by prashantcgi Quote Link to comment Share on other sites More sharing options...
dpap Posted January 10, 2014 Share Posted January 10, 2014 I am not sure if I can help further but an example file would help to see if I can seperate the prims. Quote Link to comment Share on other sites More sharing options...
gui Posted January 10, 2014 Share Posted January 10, 2014 I am not sure if I can help further but an example file would help to see if I can seperate the prims. Yeah, I think it will be usefull. Prashant, if u can draw in the image what u want as result, will be useful too. Quote Link to comment Share on other sites More sharing options...
