magneto Posted January 13, 2014 Share Posted January 13, 2014 Hi, I have a Static Object where the particles are colliding with but I also want to have an RBD Object that goes through the Static Object and collide with particles. I changed the Relationship settings in the Merge node but the RBD Object still quickly moves away from the Static Object. How can I prevent this so that these 2 objects behave as if they are independent but each affecting particles for collisions? Thanks Quote Link to comment Share on other sites More sharing options...
cwhite Posted January 13, 2014 Share Posted January 13, 2014 It sounds like there's still a collide relationship between the two objects - you probably need to turn off "Make Objects Mutual Affectors" on the solver. You can take a look at the affector matrix in the details view to see what's going on. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted January 14, 2014 Author Share Posted January 14, 2014 Thanks cwhite, I just did that but somehow the object is still quickly moving away from the static object. I will try to put a simple 2 object example together to see if it does there too. Quote Link to comment Share on other sites More sharing options...
