hscript noise - python noise1d discrepancy / confusion
bytezen
1) According to the documentation in Python, hou.hmath.noise1d, is equivalent to the noise in Hscript. Give this I would expect calling noise1d with the same parameters would produce  similar images. However, I am unable to get the same plasma-blob look using the python noise function. I have adjusted the scaling factors for TX and TZ in the python version but no matter what I choose I can not get large black sections.
(above - python version below - hscript version)
in Primitives SOP I am adding color in the red channel as follows:
hou.hmath.noise1d((lvar('TX')*0.4,lvar('TY'),lvar('TZ')*0.6))
in the hscript version:
noise($TX*0.4,$TY,$TZ*0.6)
post-10960-0-39499600-1389651614_thumb.p
2) Also according to the documentation you should be able to provide the noise1d function with a sequence of 1 to 4 numbers for different types of noise fields. I get an error whenever with the following:
hou.hmath.noise1d((lvar('TX')*0.4)) or  hou.hmath.noise1d(lvar('TX')*0.4)
Could someone educate me?
Cheers and thanks in advance!
noise testing.hipnc
first of all the help says that hou.math.noise1d() matches noise() function from VEX not HScript, and it does, so for your case put AttribWrangle SOP in set class to Primitive and type:
@Cd = 0;
@Cd.x = noise(@P*{0.4,0,0.6});
and you will see the same result as your python script in Primitive SOP (however I recommend VEX approach from performance point of view)
secondly, for sequence of 1 number you need to type
hou.hmath.noise1d((lvar('TX')*0.4, ))
it's a python thing, since (x) is not the sequence, it's one value in parentheses (x, ) is sequence with the length of one
