dayvbrown Posted January 15, 2014 Share Posted January 15, 2014 (edited) Hey hey, Having a slightly odd problem in that the ortho grid in the perspective viewport is being randomly offset and rotated from the origin... if you see the attached image that camera is basically horizontal and the origin gnomon is to the left of the origin on the grid. That view is taken at /obj/ level. Grid Display settings are all default and creating a new scene viewer can fix the problem (after a restart, a percentage of the time) but just wondering if anyone else has come across this? Currently in h13.0.283 but this has happened in previous versions as well. Thanks, Dave. Edited January 15, 2014 by dayvbrown Quote Link to comment Share on other sites More sharing options...
graham Posted January 15, 2014 Share Posted January 15, 2014 Looks like your construction plane is messed up. If you click on the [persp1] menu in the viewport, go down to Set Construction Plane menu and choose Revert to Defaults at the bottom, that should probably fix it up. Quote Link to comment Share on other sites More sharing options...
dayvbrown Posted January 15, 2014 Author Share Posted January 15, 2014 That'd be the one! Not 100% sure how it flipped about in the first place but that seems to do the job. Thanks very much, Dave. Quote Link to comment Share on other sites More sharing options...
narbuckl Posted January 16, 2014 Share Posted January 16, 2014 I have seen this happen many times. Save your scene and reload your desktop, it should reset. Quote Link to comment Share on other sites More sharing options...
